paged protocol values
Samarkande Rassil 3 years ago
in IQANdesign
updated by Gustav Widén (System support) 3 years ago •
1
I am working on an external function for a battery system.
Basically, we have many "Slave BMS" on our network and I want to see the cell voltage that they all send me thought CAN Messages. The thing is that those information are sent thought a multiplex message. So, I've used your Paged Protocol feature to indicate which data contained what I wanted and it has worked really well.
Now I want to assign a parameter to the page value. like that when I use that external function, I can setup different BMS_ID depending on my setup. However, it seems to only accept number. Is it me that is not using the correct type of channels?
Thank you for your time,
The page value (and page mask) can only be set to a fixed value.
There is a feature request on using a channel here: Adjustable GFIN Page Mask Value / Software / IQAN
