Is there a way to make the byte numbers start at 0 instead of 1 in the J1939 Frames?
afnan elhamshari 3 years ago in IQANdesign • updated by Tim Reen 3 years ago • 1
Basically the question. I am trying to get the bit and byte numbering to start at 0 instead of 1 in the J1939 frames.
You can call the first bit 0 or 1 but it really doesn't matter, the first bit is the first bit either way. If you have documentation that specifies the bit position starting with 0 then simply -1 for your position in IQAN.
