IQANrun 7 No CAN adapters found
ilyas evrensel 3 years ago in IQANrun • updated by Gustav Widén (System support) 3 years ago • 1
Image 4281
With IQAN Run 6, I was able to connect to devices via CAN and Ethernet from my computer. However, it does not see the devices in 7. If you have any ideas as to why this might happen, I would like your support.
I edited the title to include the text in the error message.
Looking at the device manager, it looks like there is no Kvaser adapter plugged in.
But the PEAK adapter (PCAN-USB) looks like it does when it is plugged in to a USB port on the PC.
An easy explanation is that another program has grabbed the adapter before IQANrun 7 started.
