j1939 parameter outputs lengths - why cant I do 3 bits? I can read 3 bits! Get errors if I try and use 3 bits on an output
Dave Hitchman 3 years ago in IQANdesign • updated by Tim Reen 3 years ago • 1
As the question asks
When I create an output j1939 parameter I am offered 1, 2, 4 bits, 1 byte (8) and 2bytes(16).
The parameter I am asked to output is 3 bits (there is a 3 bit input version of it and I am just trying to gateway it through) but I cant set the output parameter as 3 bits, I get an error
Have you tried typing the numeral 3?
Image 4297
