Deleting a connected state in a finite state machine causes IQAN design to crash
toby 3 years ago in IQANdesign • updated by Gustav Widén (System support) 3 years ago • 2
Whenever I delete a state in a finite state machine that has state trasitions connected, it crashes IQAN design. If I delete all the state transitions first, it will allow me to delete it without crashing.
Thank you, excellent description of the problem and workaround, which is to deleted the transitions first.
We have had a couple of crash reports submitted on this bug and the problem is solved in the next version, a 7.02.x maintenance release that should be ready later this month.
