SVG startup graphic issue
Jamy 3 years ago in IQANdesign • updated 2 years ago • 3
I was using SVG file for the startup graphic. It worked fine until update 7.02.20.9286. It started showing the Parker Logo. I tried deleting and re-importing. It showed imported and connected to the master module startup image, but still the Parker Logo showed at startup. So, I ended up changing the file type to PNG. This worked. Are SVG files no longer supported for startup images?
Satisfaction mark by Jamy 2 years ago
I am actually  wasn't aware that one could select SVG for the startup image.
Not sure how this could have worked. What IQANdesign does when adding SVG for an image on the display page is that it generates a PNG for each size you use.
Problem is avoided in 7.03, that has a check on startup image type (SVG not allowed).
