Working with raw values from a scaled input pin?
Matt 2 years ago in IQANdesign • updated by Gustav Widén (System support) 2 years ago • 1
Is there a way by using Qcode that I can take a scaled analog input pin, and work with the raw mV values measured at the pin?
The VIN raw value can be viewed in a measure group, but application logic will only give the channel value (scaled value).
