+4
Request for option for image gauge needles
Mack 2 years ago in IQANdesign • updated by theo mastenbroek 2 years ago • 1
Request to allow images to be used as gauge needles to allow for creation of more complicated gauge needles. In particular ones that don't go back to the base. (See picture 1) Current solution is to use a complicated mask system to fake the needle shape. Think this would also allow for gauges to be made where the gauge rotates around the needle (IE compasses with machine orientation stationary). (see picture 2) Not needed for my application but, might be useful to someone.
Image 4465
Image 4466
You can also use an image and rotate it instead of a Gauge
it works example below
just make your gauge in black and white high res and convert it to SVG
Image 4467
