RESET open load
Grisel, Evert-Jan 2 years ago in IQANdesign • updated by Chris Litwin 2 years ago • 1
Does someone knows if it's possible to reset a COUT open load error?
Now the output is disabled when a open load occurs until the system is shutdown and repowered.
The status should reset when the fault clears and the command goes to zero.
