Troubles receiving a CAN Message on JFIN
Codie 2 years ago in IQANdesign • updated by Gustav Widén (System support) 2 years ago • 1
Hello, I'm trying to use a CAN current sensors for some monitoring and I need it to be on my J1939 bus as i dont want to run a dedicated CAN network to these sensors. The messages are sent from the device as the fallowing :
Image 4499
How do I set up My JFIN channel to accept this message ?  I have my bus source address set to 3 and my destination address set to 0xF1 but I do not receive a message. I have tried several other settings but I am not able to receive the message
The IDs look like 11-bit identifiers.
To read these, use GFIN.
In the IQANdesign system layout, it is possible to mix 11-bit Generic bus and J1939.
Requires IQANdesign 6.08 or newer.
