Why is the largest value of a 32 bit integer limited in IQAN?
705David 2 years ago in IQANdesign • updated 2 years ago • 0
I am trying to store a 10 digit serial number inside my MC43FS code on IQANDesign 7.02.
Unfortunately I have found that the serial numbers always start with 2 and IQAN is limited to storing 2000000000 as an integer parameter.
The system will not accept storing 2000000001.
Why is it that a 32 bit signed integer is limited to 2000000000? The max value of a 32 bit signed integer should be 2147483647.
Edit: I should note that a text parameter cannot be used in this scenario because I must compare the serial number to see if it has been updated/changed throughout the life of the product and take action when it is changed. I am trying to avoid stripping off the 2 and including instructions for technicians to update only the last 9 digits because I can't automatically populate a 2 at the beginning in IQANRun or IQANGo. I am afraid that will net us the first 9 digits of serial numbers if techs don't read the instructions closely.
Image 4503
