IQANDesign MC43FS issue with .ism
Sayan Biswas 2 years ago in IQANdesign • updated by Gustav Widén (System support) 2 years ago • 1
I'm able to use .ism in IQANDesign under MC43 Module But unable to load i.e. ism under MC43FS module. Does MC43FS module has this limitation?
Satisfaction mark by Sayan Biswas 2 years ago
Yes, the feature for using code generated from Simulink is not safety certified and cannot run on FS modules.
To use code from a Simulink model, you need the MC4x "performance" version.
