Iqandesign 7.02 - j1939 PGN 60416 not reading off the bus
Michael Carlyle 2 years ago in IQANdesign • updated by Gustav Widén (System support) 2 years ago • 1
I updated a current program from 6.08 to 7.02 that that contains our own DM1 reader which requires reading in PGN's 65226, 60416, and 60160 for multiple SPN's from the engine.
PGN 60416 is not updating off the bus in 7.02 (it reads fine in 6.08).  I realize that there is a warning for "invalid Identifier "but that has been there in 6.08 as well and it still worked).  The values can be sniffed off the bus for the byte starting at bit 41 which can be seen changing form 202 to 227 and back but the Iqan is only reading 227 and therefor not getting the correct PGN for the BAM message (it switches between 65226 and 65251).  In Iqananalyze you can see the value is 202 but the Iqan 7.02 version of the program will not update the value for byte 6 on PGN 60416 ...it stays at 227.
Is this a glitch or is it something that has been blocked in Iqandesign 7.02 for some reason?
The "invalid identifier" warning will show for a JFIN using any of the PGNs for DM1, the PGN for DM1 and those for multipacket (TP.CM and TP.DT).
When you have a DM1IN channel in the application, the behavior used to be that JFINs with these identifier caused the DM1IN channel to not receive the messages.
From 7.01 it is the other way around; if you have the DM1IN channel it will take priority over JFINs with PGNs for multipacket.
