SEND paged protocol message
Brian Caglioni 2 years ago in IQANdesign • updated by Gustav Widén (System support) 2 years ago • 1
Is it possible to send multiplexed j1939 message? I only see this option in Frame IN, not in Frame Out
For outgoing messages, there is no special function needed. The approach you take is to enter the page value as a parameter channel.
You can have multiple GFOUT/JFOUT channels with the same identifier, and use different triggering conditions and content depending on what page you send.
