Iqan Design 7.02: can mux not correctly imported
Richard Gagnardot 2 years ago in IQANdesign • updated by Gustav Widén (System support) 1 year ago • 3
I have imported from a dbc some generic CAN frame with mux. Each mux in each frame generated have the same value: 0
Moreover, the frame with the real mux value of "0" is not imported.
Is this bug known?
Are you importing as GFIN or GFOUT?
Is the multiplexor given as a range?
There was a previous discussion in J1939 DBC importation: multiplexor issue / Software / IQAN, one of the problems was related to a range as multiplex value.
Hello Gustav,
It's imported as GFOUT (no issue with GFIN), here is the frame.
Image 4523
Image 4522
I don't think that it's the same issue as my previous topic, because I can see the different frame imported but the "VCU VDV261 Mux" is set at "0" on each frame.
Image 4524
Image 4525
Fixed in 7.05
61155GFOUT from DBC with MUX, GPOUT for page select always 0
Fixed.
