Md47 appears online but cannot connect via IQANconnect
Brandon Delgado 2 years ago in IQANconnect • updated by Gustav Widén (System support) 2 years ago • 1
Hello IQAN Connect shows the device and will indicate that it is connected. However an attempt to send file results in "no Hand shake". this is seen on D6.07 and also on IQANgo.
Image 4526
Image 4527
Image 4528
Image 4529
Thanks,
Brandon
If the connection to IQANconnect is from the Ethernet port on a master, it can take a few minutes before the status seen in the connect dialog updates.
When the system is connected via IQANgo remote assistance, the status updates much quicker.
