Not reproducible
Access violation at address 0000000002CF5E0F in module 'IQANdesign.exe'. Read of address 00000000000000A8.
Anna 2 years ago in IQANdesign • updated by Gustav Widén (System support) 2 years ago • 5
I am trying to use externals to break my project down into modules. As I am adding these modules in to the main project, I keep getting this error.  Once it occurs, the entire project file is corrupt and I get the same error every time I try to open it. I am stuck.
What version are you running?
Did you get the option to send in a crash report? If IQANdesign crashes like this, it should give an option to submit a crash report with debug information.
Yes, It did send the report, probably more than once. We are using version 7.02.33.9582. Also, I should have noted in my original post that I can reproduce the problem. I have tried starting over with a backup of the project several times, and always end up with the same error, though not from exactly the same place in my external implementation process.
Just to add to this:
Using a Variant file, attempting to break out some functions to external functions.  "Broke out" functions to external files and started the process of bringing in these external function groups to the top level file.  I've done some "debugging" to identify exactly when it breaks...
Start with variant file with "internal" functions
Add external functions reference (under application logic -> External functions) can save and reopen file
Add external function to application logic -> controller (MC43) ->target function group can save file. CANNOT reopen, file and backup is corrupted and no way to reopen or recover.  Have to use different manual backup file.
Using version 7.02.33.9582, Crash report 61161.
Please let me know if any additional info is needed.
Thanks
Not reproducible
I think this 7.02 crash might have been fixed with 7.04, there was at least one crash related to externals that was fixed.
But I'll set it as "not reproducible". Couldn't reproduce this exact one, despite the excellent error description in last post.
