SPN is represented in Motorola Format?
HÜSEYİN 2 years ago in IQANdesign • updated by Gustav Widén (System support) 2 years ago • 1
Hello; In our Deutz engine application there is a indication inside the document of spn as below
''The SPN is represented in Motorola Format. The Motorola Format does not switch the byte
ordering, so the SPN can be read directly.
The result is SPN 1208, FMI 3,CM 0, OC 10, means that the component identified by SPN
1208 has the kind of error 3 which occured 10 times since the Error Memory was cleared.
How to edit SPN in motorola format?
Image 4561
You can change the SPN conversion method on your DM1 in channel.
The default is what SAE defines as conversion method 4; least significant bit first on all 19 bits (Intel)
For a device that puts SPN in Motorola order, change conversion method to 1.
Image 4562
