Not a bug
Expression not used
D CBN 2 years ago in IQANdesign • updated by Gustav Widén (System support) 2 years ago • 2
It is possible to add an option in Project Check for retrieve the Expression not used in QCode ?
In my case, i consider that it is a bug because i cannot set correctly the result as expected
Image 4569
You wrote "reuslt". Change it to "result" and it should be fine :)
Not a bug
Thanks for spotting this Christopher-
Accidentally typing the wrong variable name adds a new variable with this name.
When that variable isn't used anywhere else, the project check will show "Expression not used"
