socket error when trying to connect to IQANsimulate
Ed Schippers 2 years ago in IQANdesign • updated by Gustav Widén (System support) 2 years ago • 1
Hi, when starting simulate form design I get the following error;
Image 4578
the simulation will run, but startup is slow, and design will not show actions (green squares)
Running 7.03
There are two possible mistakes that give this dialog in IQANdesign:
One is if you have IQANdesign communication set to Simulator, and try to measure without first starting the simulation from IQANsimulate.
The other is the port number for Simulator has been changed in either IQANdesign or IQANsimulate, so they don't match anymore. By default both are on 8325.
Since you say you started the simulation from IQANdesign, my guess is that the issue is the simulator port.
