Cyclic Timer
D CBN 2 years ago in IQANdesign • updated 2 years ago • 2
I need a cyclic timer for raise a flag all 500 ms, setting by user by parameter.
The following code raise a flag all 520 ms:
Image 4602
It is not possible to have a cyclic timer directly ? if no, how to ?
Best Regards
A simple solution using only one channel could be with the delay properties in an IDC.
Have a look at the solutions library "IDC blink" to see this idea.
With an "IDC Blink", it will not work correctly:
Delay_ON will be linked to Integer parameter in ms, and delay_off to null
In fact, total duration (Ton and Toff) shall be the value of iinteger parameter : it is the specifity of cyclic timer...
Any solution in one object can be done today ?
