Design statistics has different checksum from file info in windows explorer
Matt 2 years ago in IQANdesign • updated by Gustav Widén (System support) 2 years ago • 1
In iQAN design 6.08.32 I have noticed that the project checksum which is calculated in the project statistics window is different from the one that is displayed when I right click the .idax file in windows explorer, select properties, then file info.
Why is this?
File info window
Image 4605
Statistics window when the file is opened in 6.08.32.8219
Image 4604
If you look at the project checksum in IQANdesign in statistics just when you open the file (in the IQANdesign version it was last saved in), it should match.
Any change you make in IQANdesign will change the checksum you see in the statistics window in IQANdesign, even if you haven't saved the file.
