Enabled adjust item but locked anyway?
Jean-Philippe 2 years ago in IQANrun • updated by Gustav Widén (System support) 2 years ago • 1
I have this external function that, for an obscure reason, is not allowing the adjust items from being modified. I created new adjust groups in the main project with the same adjust items and they are still locked. I created new adjust items from scratch in the external function and they also show as locked, even though they are set to Enabled (as shown).
Is there a way to disable ALL adjust items from an external function? I feel like there is a hidden property somewhere that needs to be toggled that I can't see.
I'm currently working with IQANDesign 6.08.28.8214, I also checked release notes up to latest IQAN7 and could not find anything related to a known bug solved in more recent releases.
Thanks,
JP
Image 4612
Image 4613
Is it a multi-master system?
In IQANrun 6, the padlock symbol is shown in this way on adjust item when the channel is disabled, and also when the channel is on a module you do not have contact with.
With IQANrun 7, adjust items appear grayed out with a padlock symbol for the same situations, but will give you an error message about No contact if you click the adjust item and the problem is No contact.
