How can we assign items to adjust groups if they're imported as an external function in an IQAN Design program?
Amin Syed 2 years ago in IQANdesign • updated 2 years ago • 2
I'm new to IQAN and while copying an existing Function group in the application logic section I came accross the fact that all links are now broken (Which makes sense). Is there:
1. An easier fix to align i/o mapping and logic connections apart from manually doing it for everywhere the links broken in the program (like a list for I/O)? In my case I have product 1 and product 2 that I need to configure to 2 pages on a HMI screen and then copy the screen to another one available elsewhere.
2. A series for IQAN design that explains how the copy of a function group can easily be configured?
3. And How can we assign items to adjust groups if they're part of an imported external function in an IQAN Design program?
For question 3:
In the external function, you can make channels adjustable by dragging them to the list of adjust items.
These adjust items become available in the main project when adding an instance of the external function. You then add an adjust group in the main project and drag the adjust items to it.
Adjust item names can be changed in the main project.
