Delay for Analog Signal
Lars Bolduc 2 years ago in IQANdesign • updated 2 years ago • 3
Is there a way to delay an alalog signal?
I've tried Math Channel, Qcode, Slope/Filter Channel...
Using calculation order to get a cycle delay per math channel. Really would prefer a more elegant/flexible solution.
Not sure how long a delay. You could just stuff an array like a buffer and just us nth value of that array. Again depending on how long of a delay this array may be large.
Did result in simpler code, thank you for the suggestion.
