How to calculate a running Maximum value
Guy 2 years ago in IQANdesign • updated 2 years ago • 2
I'm new to Iqan so I apoplogize for the basic question. But, is it possible to calculate a running maximum input value with only the previous 20 or 30 sample. I don't want to consider the entire data series, only the values immediately before the current value.
Thanks for the help
One way to do this could be with an array channel, attached is an example with 20 samples.
running max.idsx
This is how it could look when testing:
Image 4679
This is perfect. Thank you!
