IQANdesign shortcut ideas
A DOMS 2 years ago in IQANdesign • updated 2 years ago • 1
When I am in the Property Inspector, I would like to get out by tapping ECHAP key and then be abble to select an other chanel with the arrows.
Can you add the shortcut F8 to Disconnect IQANdesign from the controller,
to be abble to connect IQANrun fastly.
(If not connected to the CANadpatator, you can let the shortcut to open the simulator.)
It's easy to connect IQANrun now juste by tapping F8 and then Enter to connect CAN and then Enter to log.
But complicated to disconnect from Design. Same shortcut could be very helpfull and efficient.
