Shut down procedure of MD4 system
Melker Göransson 2 years ago in IQANdesign • updated by Gustav Widén (System support) 1 year ago • 2
What is the proper way off powering down an iqan system with an MD4 display and some XC-modules? Any special concerns regarding power off to not make corrupt paramters saved for example? Please advise. Are there any software power off possibility or just removing the supply voltage to power off? Thanks,
No, there are no special considerations for shutdown.
You can just remove the supply voltage.
Only time you should not shut off the unit is if you are downloading to the unit.
But even that will not break the unit, you will just need to download the application again.
