Startup Screen Bug
Kevin 2 years ago in IQANdesign • updated by Gustav Widén (System support) 7 months ago • 9
I'm having trouble using the start-up screen. I noticed the customers logo was not displaying correctly so tried a different image. Appears to be the same result if I use the graphic as a JPG or BMP. Seems to delete the colour and make the whole image slanted, with lines appearing horizontally throughout the graphic and diagonal line.
MD5-8 IQANdesign 7.04.8.
Image in Paint:
Image 4742
Image shown on MD5 Startup:
Image 4743
share your image file please
Does it help if you set left upper pixel to black color ?
Or else  image size the same as the display size (= recommended) ??
There seems to indeed be something wrong with the startup image on the MD5.
Tested the same as you and also got a slanted image.
But it seems to be when you have a red text this happens, other colors seems to cause the image to go black and white.
We will look in to this.
This should now be solved in the next release (7.05)
Updated system to 7.05 but seems to have changed my start-up logo that's red, to blue. Checked the image in the project and it still remains red in the viewer. The slanted image is no longer an issue but the colour still remains a problem for me.
Hello Kevin.
There seems to still be issues with the startup images colors.
From what i can tell it depends on what type of image i am using.
If i use a PNG image the red color will sometimes become grey.
Seems to depend on background color or if there are any other colors in the image.
If i use BMP i get the color swat as you describe where red becomes blue and so on, almost like the image has inverted colors.
If i use JPG i have not managed to get any wrong colors for the startup yet.
So JPG seems to be the best option for startup images.
