Property inspector: Property and value rows don't line up.
Matt 2 years ago in IQANdesign • updated 2 years ago • 5
In design 7.04.8.10088, if you click on an item under the property column in the property inspector window, the corresponding item in the value column is shifted down.
Image 4756
Image 4757
It looks like some scaling issue, the button for the drop down list seems larger than it should be for this text size.
Did you encounter this glitch when moving the IQANdesign window between displays with different scale?
Nope, I'm encountering it on the same display in which the program was opened on. Both of my displays have resolution and scaling set identically. Although, the program seems to be working fine today. I'll keep an eye out and will post back if I figure out how to reproduce it.
Not able to reproduce the property inspector issue, but there is a glitch that causes the program send window to appear partially cut off while sending.
Image 4758
I'm also seeing a hard to reproduce glitch that causes the last item in a PGN group in the CAN database to duplicate when highlighted or occasionally hovered over. Again, I'm having issues figuring out a repeatable method of duplicating these.
Image 4759
What scaling and resolution are you using? Could it be that you use custom scaling?
If the problem with the misaligned property values and cut off dialog box came when changing scaling, then I would not be that surprised. It seems strange that it would come when scaling isn't changing.
I'm using a resolution of 2560x1440 and scaling of 125%. I can confirm that the issues in my last comment with the send dialog and CAN database happened without scaling changing. The laptop was connected to the dock the entire time design was open.
My laptops built in monitor is a different aspect ratio, so that might explain what was happening in my original post, but I'm not sure if I had the program open when I wasn't connected to my dock.
