Get project - module not found
MSM 2 years ago in IQANdesign • updated by Gustav Widén (System support) 1 year ago • 3
Hello - I'm trying to 'Get Project' from an older MD4-7 via Ethernet connection from PC to the display C3.  IQAN Design can see the display (listed in the subwindow), but when I try to proceed I get the error box: "Incomplete System" "Operation was aborted. The following modules were not found: MD4-7[1] (Optional)"
This indicates that this is a multimaster application with two MD4-7 masters.
You can not use IQANdesign to get incomplete applications.
You need to have all masters online if you want to be able to get the application.
You can however use IQANrun to get a clone from a incomplete system.
You can use that incomplete clone file to download to a new master if that is what you need to do.
But you will still not be able to open the incomplete clone in IQANdesign.
Thank you for the reply.  This project is old enough that I had forgotten there was a second screen added to the network - didn't remember until your answer.
