Wire kit 20085205 missing Address wires for MD5?
Jacob Meng 2 years ago in IQANdesign • updated by Jos Lentfert 2 years ago • 4
Wire kit 20085205 does not have C1:31 and C1:45 for an address tag even though it is shown on the pinout. Is there an internal selectable tag? Do I need to manually add these wires?
The address tags will plug directly into the MD5 connector. I have found that pinning out the wires to a termination block and adding the address tag there can be unreliable and cause issues down the road, so it is best to just have it directly plugged in to the connector.
I don't recommend using non-IQAN ID Tags. Very hard to hit the specific resistances needed.
You just plug these into the connector pins.
IQAN addressing and terminating resistor tags | Parker NA
Thanks all, I do use standard IQAN ID tags. I was just wondering where the standard prewired wire was since I typically install the ID tags in a terminal block in the electrical enclosure. After the above comments, I will just wire directly to the plug on the back of the MD5. Thanks!
See Accessories catalog for the ID tags with matching pins for insertion in connector
 IQAN_Accessories_Catalogue_MSG17-8319_UK.pdf
