Controller Capacity
Nur 1 year ago in IQANdesign • updated by Anders Olsson 1 year ago • 1
Where can we learn the capacity of the processor of the MC42-MC43 controllers, how much of it we use, and how much we need to use?
You can seen the estimated memory usage under Project-> Statistics.
To read the actual CPU load and memory usage you need to add a readout-function in the program and then view the value while the program is running in the MC-42/43.
The readout-function is found under Add-> Miscellaneous->System information.
Then select the property you want to view under Value, for example Application-> Cycle utilization [%]
