Connection lost during SW update
Michael Carlyle 1 year ago in IQANdesign • updated by Gustav Widén (System support) 12 months ago • 9
There is definitely a repeatable problem with 7.05.  I have loaded 3 different programs with no changes other than updating to 7.05 from 7.04 and they all stopped after loading the two MD4's when it tried to load the first MC43 (we have two MD4's and 3 MC43's in all these machines).  Disconnected and no replay from the MC43.  I tried both IqanDesign 7.05 and IqanRun 7.05 with the same results.
Image 5006
Image 5005
We also had this when updating a MD5-8 & MC43FS system from 7.04 to 7.05 via G12. Once it crashed out we couldn't reconnect using G12 at all, MD5 was displaying no application and it refused to connect because it couldn't see the MC43 (an error dialogue box in IQAN run).
Had to hardwire into the CAN to recover the system. This was stable and appeared to be OK.
Kevin,
If this update with G12 with IQANgo remote assistance, this fix in Release notes - IQANdesign 7 should be the solution:
IQ-13729Problems updating multi-master via IQANgo remote assistance
Updating multi-master systems with 7.05 via G12 and IQANgo remote assistance could fail. Fixed.
Topic created from comment in IQANdesign 7.05 released, CAN FD on diagnostics bus / Software / IQAN
Michael,
I believe there might be something system specific triggering the problem.
When a system with two MD4 modules is updated in one go, the MD4 with the Ethernet connection will be quick while one MD4 will get firmware and application update over the 250 kbps CAN. The complete update could then easily take 15 minutes. But unless there is something else going on, it should go through.
-Did the MC43 modules show any unusual blink code?
-Are there any other CAN nodes than the five IQAN masters on the Diagnostics bus?
-Any indication that there could be physical issues on CAN, for example number of terminations?
No other Can nodes on the diagnostics/master bus....all Iqan Master modules.  Terminations are fine (loaded 7.04 no problem)...when I loaded the 7.05 it would stop after loading the MD4's every time when it started to toad the first MC43 (address tag 3).  After it stopped i had to restart the system with mismatch and load the program and it takes after the key cycled.
It is a combined Diagnostic and Master bus if you want to do a test setup there.
I've managed to reproduce the case with 2xMD4 and 3xMC43. In my tests it did not fail consistently, but often enough to be a problem.
It might be related to the time the MC4 modules have to wait while the second MD4 is being updated over CAN. Investigating.
Planned
Brief update, it seems as if the problem is related to total number of master modules taking the update.
Physical restart and repeating the attempt to send the update over IQANrun is a workaround.
A fix would probably be on the PC tool.
Problem with updating the system with multiple MD4s and MC4x modules is fixed in IQANdesign 7.05.27 / IQANrun 7.05.32.
The fix requires updating both the project file and the SW tool.
IQ-13650Connection lost with MC4 on upgrade to 7.05 in multi-master system
Could happen in large multi-master systems when upgrading from a version prior to 7.05.Fixed.
