IQAN Design 4.02 issues
ksilovich 10 years ago in IQANdesign • updated by Ulrik Zakariasson (Software development) 9 years ago • 2
2 issues I have ran across with IQAN Design 4.02.16
1) Some time when working the Select All function stops working. I have to close the program and restart it to use it again.
Image 403
2) When resizing a Comment Box it will jump left and up quite a bit. It doesn't stay fixed in the location it was in before.
On a side note of that it would also be nice that when you copy and paste a comment it remains the same size. Currently when you past it it goes to a define size instead of what was copied.
Thank you for reporting these issues. The problem with comments moving when resizing has been fixed in our upcoming release 4.03. The others are being investigated.
Comments will now keep their size when pasted using IQANdesign 5.
