DTC Simulation in Version 7
J C. Crow 1 year ago in IQANsimulate • updated 1 year ago • 3
The DTC simulation doesn't seem to be working correctly in version 7. When you change the value to a number above -1, you cannot go back to -1 to turn off the DTC. It will only go back to 0.
Image 5034
Image 5035
I am using 7.04 and it is working (will go back to -1).
I was on 7.02. It was not working. I updated to 7.05 and it still is not working. I tried typing -1 and that does not work either.
I guess its not that big a deal. If you close the box, it goes away.
