Read External TSC1 request
Marcel 1 year ago in IQANdesign • updated by Michael Carlyle 1 year ago • 1
I tried to read the TSC1 message from an extrernal source with an J1939 module and an MD5-10. I have some difficulty with it. Should this be possible or can iQan only send this parameter and not read it? It works with a generic module, but I don't like to connect another CAN bus as they cannot use the same CAN bus.
You should be able to read TSC1 on PGN 0 from the Source Address of the controlling module and break it down into it's parameters.
