Not reproducible
MD5-12 Backlight Issue
ksilovich 1 year ago in IQANdesign • updated by Gustav Widén (System support) 7 months ago • 3
If you try to control the backlight of an MD5-12 with an Integer channel,  the display will flash off about every 5 to 10 seconds.  If I turn the control to not used.  Then the backlight stays at the level that is selected in the menu system.
This is not an issue with the 8 or 10 display,   Just the 12"  Using the latest version of 7.05.
Hello Ksilovich.
I have tested with two different MD5-12 and can not get the behavior you are describing.
Both with Integer parameter and integer math channels.
Would it be possible for you to share the application you see this behavior with?
This truck is at AUSA in Parkers booth.   Once I it gets back from the show, I will change the program back to when it was acting up, take a video and send the application on over to you.    It will be a week or so, as the show just started.
Not reproducible
Never managed to reproduce the issue, but 7.06 that is just released has updates that could help.
