+3
IQAN Simulate 7 cannot see logic process in Design
J C. Crow 1 year ago in IQANsimulate • updated by Lars Olsson 2 months ago • 5
IQAN Simulate 7 is operating different than previous versions. You can no longer see the logic processing in IQAN Design when you use the Run button. In simulate, you cannot see the function group logic to see which objects are true/false. This significantly reduces the debugging usefulness of IQAN Simulate. I am doing something wrong?
I have the same issue too.  I have not taken time to ask yet. Most of the time when I am using simulate, I change parameters in simulate and see the results in IQANdesign.  This allows me to change values in one function group and view what happens in another function group real time.
Have you figured this out at all - I have the same Issue
When I updated to IQANdesign 7.05,27.10982 it appears to be resolved.  I did not see anything in the release notes about this issue though.
Same here. When up updated design and simulate to the latest version, things are working properly.
I still get this problem even with the latest versions. Not if I create a new project but with a project that has been updated with latest IQANDesign.
IQANDesign 7.06.22.11482
IQANSimulate 7.06.7.7478
Is there a known reason for this to happen?
