DIN/VIN Error !!! 0.00 mV
Adrien Léauté 10 months ago in IQANrun • updated by Thomas Moberg (System support) 10 months ago • 3
What does !!! 0,00 mV mean in the Log's status ?
Image 5189
The '!!!' means its in a disabled function block
ok thanks, it means it's not really in use ?
I can see in the bottom line Pin C1:39 Hors Service (mean Disable)
Just to be clear, this is not the log.
This is a measure group.
And yes the !!! can indicate that the function group where the VIN is located in application is disabled or the expansion module could also be disabled, but it can also indicate that you have an error on the channel like High or Low error.
In this case where it say disable it should be a disabled function group or disabled expansion module.
