qcode zoom
Rick Yorke 10 months ago in IQANdesign • updated by Gustav Widén (System support) 9 months ago • 3
IQAN design 4 had the feature of being able to right mouse click scroll to zoom in/out on the Qcode. This feature has disappeared with IQAN design 6 and 7. Was this an intentional deprecation?
Having the zoom feature on the channels is nice, but I do miss the Qcode zoom. Also running into an issue with using a laptop and additional monitors where it seems the resolution from the laptop is being applied to the Qcode on the additional monitor.  Additional monitor has higher resolution so my Qcode appears very small and I can't zoom in on it.
If I close the laptop and only use the additional monitors and open Design. The Qcode appears larger and this resolution is maintained when I open the laptop.
I actually don't recall that there ever was a zoom feature in the Qcode view. How did you get it to zoom the text size?
With IQANdesign 4.07.15.4769, Opening a channel which has Qcode, hover the mouse cursor in the Qcode window. Click and hold left mouse button, use the mouse scroll wheel to zoom the text in/out.
Thanks. I had never noticed this existed, I don't think it was a documented feature.
But I can see it is a nice tool, changing topic to feature idea.
