+3
Changing adjust items from iqan design
Mats 10 months ago in IQANdesign • updated by Gustav Widén (System support) 9 months ago • 1
It seems like a missing feature in IQAN Design is the ability to change the states of adjust items from IQAN Design code. For instance if I want a user to be able to change a number using the adjust menu, but then after a certain time or without usage, change it back to its regular value. Or if I have a digital parameter and want it to switch back off directly after clicking it to true.
Is there a work around to get this functioning currently?
I got confused by the title at first, but the request seems to be to be able to trigger a change of an adjustable value from application logic.
Among the solution library examples, you find some templates for how you could implement an automatic reset using MEM channels:
Image 5219
