Planned
Scrolling in User Interface
Marnix 10 months ago in IQANdesign • updated by Gustav Widén (System support) 6 months ago • 9
We are experiencing a user interface issue in Iqan Design 7.05.19.10562.
When editing a page on the display and scrolling in the Layers panel (for example towards the bottom), the main screen keeps scrolling along with it.
Even though the mouse cursor is positioned in the layer navigator, the display view continues to move.
This makes working quite difficult. Ideally, the scroll action should only affect the area where the mouse cursor is located, and the display view should remain in its current position.
Has anyone encountered this behavior before, or is there a setting to prevent the screen from scrolling together with the layer panel?
Thanks.
It looks like you are using the scroll wheel, do you experience the same behavior if you use the slider or arrow keys?
Yes using the scroll wheel.
When I use the sliders, it wont happen.
Is there a setting for this somewhere?
I am also having this same issue with the scroll wheel and was wondering if there is any updates on a fix?
I have this problem with the arrow keys. When I edit the position of an item with the arrow keys, the layers menu moves as well
I checked and could confirm both the issue with using the scroll wheel in the list of display controls, and Ctrl-arrow for repositioning display controls.
Planned
Will be fixed in next release.
