Export Logs to XML
John Andruch 9 months ago in IQANrun • 0
I recently migrated to 7.05 IQAN suite from the 6 version. I noticed that the ability to export logs into XML has been removed. I just completed an automatic data load process that uses XML. I chose XML because it provided more metadata around which machine and when the information was being pulled. Can we get this functionality reinstated?
