SPN 4207 checksum support
JohnNix 8 months ago in IQANdesign • updated by Gustav Widén (System support) 7 months ago • 1
I've been using the CRC parameter in IQAN design for J1939 messages that require SPN 4206 (rolling counter) and SPN4207 (checksum). I can't find a configuration that works. I assumed that the "J1939 checksum" option was for SPN4207 but that doesn't seem to be the case (I just get checksum errors from the destination device). Am I missing something or is the CRC parameter not configurable for SPN 4207? I'm having to do it the long way around doing the calculation (it works but it's very messy). SPN4207 is a 4 bit checksum (as below), SPN4206 is a 4 bit rolling counter.
Checksum =
(Byte1 + Byte2 + Byte3 + Byte4 + Byte5 + Byte6 + Byte7 +
message counter & 0x0F +
message ID low byte + message ID mid low byte + message ID mid high byte + message ID high byte)
Message Checksum = (((Checksum >> 6) & 0x03) + (Checksum >>3) + Checksum) & 0x07
The J1939 checksum that is currently (7.05) available in the dropdown on the IQANdesign CRC channel is the same as SPN 3188 and SPN 3690.
It seems as if several devices now have proprietary messages using the SPN4207 checksum, in current versions of IQANdesign that method is only for TSC1.
Changing topic from question to feature idea.
