MD4 Log
Rene Arevalo 7 months ago in IQANdesign • updated 7 months ago • 4
An XC43 sent a COUT error to the MD4 display, which is the master module in the CAN bus network. However, the error was not logged in the MD4 log. Any idea why this might be happening?
if this is on start up, it may be because the expansion is waking up faster than the display
The error appeared within an hour after the machine was started.
Check that the System log isn't disabled.
Check that the System log is set to Continue logging when full.
Measure the System Information Channel Log Queue  over time, if this is high you could miss log events.
Thank you all for the replies.
-The system log is not disabled, and it is set to "Continue logging when full."
-Soon, I will measure the information channel -I will share the results.
