Exporting image groups causes image file names to change
Matt 6 months ago in IQANdesign • updated by Gustav Widén (System support) 6 months ago • 1
If I export an image group in iQAN 7.06.22, any images with a period in there name in iQAN will export without the period and anyting that follows the period. It does not matter if what follows is text or numbers.
Example: Image named "test-circle-5.2" will export as "test-circle-5"
