Invalid vmAC resource in IQANrun
Ryan 5 months ago in IQANrun • updated by Thomas Moberg (System support) 5 months ago • 3
Customer is getting "Invalid vmAC resource for MD4-7(0)" when trying to flash a clone to a MD4 with IQANRun7, lastest rev. Any ideas? Do they have an address tag issue? Thank you
Image 5345
There is not anybody that knows what this error is and what caused it?
Thanks
Hello Ryan.
Have not seen this message personally but this has nothing to do with the ID-Tag, even with the wrong tag you will not get this message.
This sounds like something has gotten wrong with the vmAC part of the file.
Is it a single file that has this issue or is it more?
When you take a clone from a system the computer stores a local cash of that firmware version so you do not have to get it next time you take a clone with the same version.
If that file got corrupted all clones taken after that with the same version and master will use the corrupted file.
That could perhaps cause this message.
I also changed the topic of this post to clarify a bit.
