IQANdesign 4.03 released
Gustav Widén (System support) 10 years ago in IQANdesign • updated by anonymous 9 years ago • 0
Highlighted features
MD4: Support for rotating images
Added new property Rotate on Image controls.
Image 413
Example usage, a wheel position indication for all-wheel-steering:
Image 414
Pixel size at font size properties
In addition to the predefined font sizes (Tiny, Small, Medium, Large, Huge) it is now possible to enter the font size in pixels directly (as an integer). Implemented for label and value controls.
Application documentation, add adjust items
Included adjust items and parameters with limits in the auto generated project documentation. Image 415
Remove logging of saturation warning
Logging of the COUT saturation warning is now removed. COUT status will still indicate if the output is saturated (unable to drive the commanded current).
IQAN-SV Add module info in menu system
Information about an IQAN-SV camera can now be shown after it has been assigned by selecting the camera in the camera menu.
Image 418
For more info on feature updates and problems solved, see release notes
