Current Output channel only outputing min or max values, not ramping.
NEricson 3 months ago in IQANdesign • updated by Thomas Moberg (System support) 3 months ago • 1
I have multiple machines programmed with the same program. One machine has a Current Output channel that wont ramp with the input channel. Once it sees a value it jumps to 100% output instead of ramping. Ive tried changing from (Multiply%) to (AbsoluteMaxOf) even thought it has 1 controlling line. In the process of diagnosing we've even tried 7.05 and 7.06. Again I have identical machines with identical programs and they operate correctly. Error1.mp4
Error2.mp4
Have you checked what the output is adjusted to in the machine?
If you somehow have managed to adjust the min current to be at 800 also you will get this.
